주요 콘텐츠로 건너뛰기
Nikon Coolpix AW130 Front Panel Replacement
필요한 것
  1. Nikon Coolpix AW130 Front Panel Replacement, Battery: 1 단계, 이미지 1/2 Nikon Coolpix AW130 Front Panel Replacement, Battery: 1 단계, 이미지 2/2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Front Panel Replacement: 2 단계, 이미지 1/2 Nikon Coolpix AW130 Front Panel Replacement: 2 단계, 이미지 2/2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Front Panel Replacement: 3 단계, 이미지 1/1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Front Panel Replacement: 4 단계, 이미지 1/2 Nikon Coolpix AW130 Front Panel Replacement: 4 단계, 이미지 2/2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Front Panel Replacement, Front Panel: 5 단계, 이미지 1/2 Nikon Coolpix AW130 Front Panel Replacement, Front Panel: 5 단계, 이미지 2/2
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Front Panel Replacement: 6 단계, 이미지 1/2 Nikon Coolpix AW130 Front Panel Replacement: 6 단계, 이미지 2/2
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Lauren Stepp
회원 가입일: 01/29/16
1,251 평판
안내서 8개 작성하였습니다
댓글 한 개
Hello, has this front panel influence on cameras sealing function? Or is it only as shield against mechanical demage?
Slavomir - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,429
