소개
The shutter button can oftentimes get caked with mud. Because it isn't fixed with screws or glue, it can also become stuck from constant use. Simply replacing the entire button, after removing the front panel and side buttons, is a simple fix.
필요한 것
Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
Carefully pull the plate off of the face.
다른 2명이 해당 안내서를 완성하였습니다.
