주요 콘텐츠로 건너뛰기
Nikon Coolpix B700 Button Assembly Replacement
필요한 것
  1. Nikon Coolpix B700 Button Assembly Replacement, Back Frame Assembly: 1 단계, 이미지 1/1
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Button Assembly Replacement: 2 단계, 이미지 1/1
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Button Assembly Replacement: 3 단계, 이미지 1/2 Nikon Coolpix B700 Button Assembly Replacement: 3 단계, 이미지 2/2
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Button Assembly Replacement: 4 단계, 이미지 1/1
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Button Assembly Replacement: 5 단계, 이미지 1/3 Nikon Coolpix B700 Button Assembly Replacement: 5 단계, 이미지 2/3 Nikon Coolpix B700 Button Assembly Replacement: 5 단계, 이미지 3/3
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Button Assembly Replacement: 6 단계, 이미지 1/1
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Button Assembly Replacement: 7 단계, 이미지 1/2 Nikon Coolpix B700 Button Assembly Replacement: 7 단계, 이미지 2/2
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
  8. Nikon Coolpix B700 Button Assembly Replacement, Button Assembly: 8 단계, 이미지 1/1
    • Lift the corner under the power button up.
    • While at the same time pushing the selector knob back.
  9. Nikon Coolpix B700 Button Assembly Replacement: 9 단계, 이미지 1/1
    • This should remove the entire assembly from the camera housing.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Carlos Salgado
회원 가입일: 02/27/19
1,429 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 25
전체 시간: 458
