소개
This guide shows how to replace the assembly of the shutter button/mode selector dial/buttons. This assembly can be replaced if any of the buttons malfunction or are faulty. The back cove and bracket need to be removed before removing the button assembly.
필요한 것
Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
Lift the corner under the power button up.
While at the same time pushing the selector knob back.
다른 3명이 해당 안내서를 완성하였습니다.
