소개
The LCD screen can be easily replaced without removing any other parts from the device. If the LCD screen is cracked or the backlight is inoperable, refer to this replacement guide.
필요한 것
Use a Phillips screwdriver to remove the two 3.5mm screws at the top and bottom of the LCD Screen.
이 단계에 사용된 도구:Desoldering Pump$3.99
Use the solder gun and desolder the yellow and blue wires.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Hi, I like the first 6 steps, but what are the rest of the steps?
