주요 콘텐츠로 건너뛰기
Nikon Coolpix B700 Lens Assembly Replacement
필요한 것
  1. Nikon Coolpix B700 Lens Assembly Replacement, Back Frame Assembly: 1 단계, 이미지 1개 중 1개
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Lens Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Lens Assembly Replacement: 3 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Lens Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Lens Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Lens Assembly Replacement: 5 단계, 이미지 3개 중 1개 Nikon Coolpix B700 Lens Assembly Replacement: 5 단계, 이미지 3개 중 2개 Nikon Coolpix B700 Lens Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Lens Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Lens Assembly Replacement: 7 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Lens Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
  8. Nikon Coolpix B700 Lens Assembly Replacement, Internal Bracket: 8 단계, 이미지 1개 중 1개
    • Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
    • Remove the single 6mm screw.
  9. Nikon Coolpix B700 Lens Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Insert the pry tool under the latch and gently lift up to remove the ribbon.
  10. Nikon Coolpix B700 Lens Assembly Replacement: 10 단계, 이미지 1개 중 1개
    • Move the ribbon out of the way to reveal the hidden screw.
  11. Nikon Coolpix B700 Lens Assembly Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the button assembly gently to give access to remove the 4mm screw.
  12. Nikon Coolpix B700 Lens Assembly Replacement: 12 단계, 이미지 1개 중 1개
    • On the top of the camera, remove the 6mm screw.
  13. Nikon Coolpix B700 Lens Assembly Replacement: 13 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Lens Assembly Replacement: 13 단계, 이미지 2개 중 2개
    • With the spudger tool gently pry off the white tap holding in the bracket.
    • Use the same tool to remove the glued-on ribbon.
  14. Nikon Coolpix B700 Lens Assembly Replacement: 14 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Lens Assembly Replacement: 14 단계, 이미지 2개 중 2개
    • Gently lift up the button assembly to slide the bracket out.
  15. Nikon Coolpix B700 Lens Assembly Replacement: 15 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Lens Assembly Replacement: 15 단계, 이미지 2개 중 2개
    • With the pry tool gently lift up the latch and pull the cable toward the lens assembly.
    • Use the pry tool again and place it under the ribbon and lift straight up to disconnect the ribbon.
  16. Nikon Coolpix B700 Lens Assembly Replacement, Lens Assembly: 16 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Lens Assembly Replacement, Lens Assembly: 16 단계, 이미지 2개 중 2개
    • Use the Phillips screwdriver to remove the four 6 mm screw that hold on the bracket housing.
  17. Nikon Coolpix B700 Lens Assembly Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the tripod mount from it's slot.
  18. Nikon Coolpix B700 Lens Assembly Replacement: 18 단계, 이미지 3개 중 1개 Nikon Coolpix B700 Lens Assembly Replacement: 18 단계, 이미지 3개 중 2개 Nikon Coolpix B700 Lens Assembly Replacement: 18 단계, 이미지 3개 중 3개
    • Now you just have to slide the lens assembly out of the housing.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Carlos Salgado
회원 가입일: 02/27/19
1,456 평판
안내서 7개를 작성함
2가이드 댓글
how to reset an objective error on B700 ? the lens is stopped in the middle of a hike
Per Benny Paulsen - 답글
how to reset an objective error? the lens is stopped in the middle of a hike
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 52
전체 시간: 3,490
