소개
This guide will walk you through the necessary steps to remove the back panel of the Nikon Coolpix E5700.
부품
부품은 필요하지 않습니다.
  1. Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Pull the battery out of the E5700.
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
    • Turn to the bottom of the camera.
    • Remove the two Phillips screws located directly below the back monitor
    • Turn the camera to the side with the memory card slot and open the compartment for the CF card.
    • Remove the top two Phillips screws closest to the back panel.
    • Turn to the back of the camera.
    • Remove the top most Phillips screw on the back panel.
    • Turn to the last side of the back panel.
    • Remove the Phillips screw below the eyepiece.
    • Remove the Phillips screw located above the speaker.
    • Gently begin to remove the back panel.
      • Caution: There are two bundles of wires connecting the back panel to the camera. Be sure not to pull too hard and yank these out.
    • Now gently unplug the two wires at the bottom of the panel.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Raana
회원 가입일: 2011년 04월 12일
78 평판
안내서 2개 작성하였습니다
Cal Poly, Team 24-58, Amido Spring 2011 Cal Poly, Team 24-58, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G58
4 회원들
안내서 9개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 1,697
