소개
This guide will walk you through the necessary steps to remove the back panel of the Nikon Coolpix E5700.
필요한 것
Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
Open the battery door.
Turn to the bottom of the camera.
Remove the two Phillips screws located directly below the back monitor
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
