주요 콘텐츠로 건너뛰기
Nikon Coolpix E5700 Rear LCD Replacement
필요한 것
  1. Nikon Coolpix E5700 Rear LCD Replacement, Battery: 1 단계, 이미지 1/2 Nikon Coolpix E5700 Rear LCD Replacement, Battery: 1 단계, 이미지 2/2
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Nikon Coolpix E5700 Rear LCD Replacement: 2 단계, 이미지 1/1
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Nikon Coolpix E5700 Rear LCD Replacement, Rear LCD: 3 단계, 이미지 1/1
    • Remove two Phillips screws (3.4 mm) located on the left side of the screen.
  4. Nikon Coolpix E5700 Rear LCD Replacement: 4 단계, 이미지 1/2 Nikon Coolpix E5700 Rear LCD Replacement: 4 단계, 이미지 2/2
    • Remove two Phillips screws (3.4 mm) located on the right side of the screens.
  5. Nikon Coolpix E5700 Rear LCD Replacement: 5 단계, 이미지 1/2 Nikon Coolpix E5700 Rear LCD Replacement: 5 단계, 이미지 2/2
    • Remove back plastic monitor cover.
  6. Nikon Coolpix E5700 Rear LCD Replacement: 6 단계, 이미지 1/1
    • Remove the Phillips screw on the top right side of the screen.
  7. Nikon Coolpix E5700 Rear LCD Replacement: 7 단계, 이미지 1/1
    • Carefully unplug the grey bundle of wires in the white housing.
  8. Nikon Coolpix E5700 Rear LCD Replacement: 8 단계, 이미지 1/1
    • Carefully unplug the small pink and wires in the grey housing.
  9. Nikon Coolpix E5700 Rear LCD Replacement: 9 단계, 이미지 1/1
    • Remove the two Phillips screws on the left side of the screen.
  10. Nikon Coolpix E5700 Rear LCD Replacement: 10 단계, 이미지 1/1
    • Remove the metal bar on the left side of the screen.
    • Remove the screen from the front plastic housing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kyle Sitton
회원 가입일: 04/17/11
351 평판
안내서 7개 작성하였습니다
Cal Poly, Team 24-58, Amido Spring 2011 Cal Poly, Team 24-58, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G58
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,373
