소개
This guide will walk you through the necessary steps to remove the speaker in the Nikon Coolpix E5700.
필요한 것
Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
Open the battery door.
Turn to the bottom of the camera.
Remove the two Phillips screws located directly below the back monitor
Finish pulling away the back panel.
Turn the camera to its non-grip side.
Remove the Phillips screw located above the strap holder.
In order to pull the top panel without removing the flash unit. You must remove the flash top cover, taking away the screw under the bulb (see image). then gently remove the plastic top cover. IMPORTANT: discharge the condenser as soon as possible (the flash wires are now exposed, and dangerous ).
다른 한 분이 해당 안내서를 완성하였습니다.
