주요 콘텐츠로 건너뛰기
Nikon Coolpix E5700 Viewfinder Replacement
필요한 것
  1. Nikon Coolpix E5700 Viewfinder Replacement, Battery: 1 단계, 이미지 1/2 Nikon Coolpix E5700 Viewfinder Replacement, Battery: 1 단계, 이미지 2/2
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Nikon Coolpix E5700 Viewfinder Replacement: 2 단계, 이미지 1/1
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Nikon Coolpix E5700 Viewfinder Replacement, Back Panel: 3 단계, 이미지 1/1
    • Turn to the bottom of the camera.
    • Remove the two Phillips screws located directly below the back monitor
  4. Nikon Coolpix E5700 Viewfinder Replacement: 4 단계, 이미지 1/2 Nikon Coolpix E5700 Viewfinder Replacement: 4 단계, 이미지 2/2
    • Turn the camera to the side with the memory card slot and open the compartment for the CF card.
    • Remove the top two Phillips screws closest to the back panel.
  5. Nikon Coolpix E5700 Viewfinder Replacement: 5 단계, 이미지 1/1
    • Turn to the back of the camera.
    • Remove the top most Phillips screw on the back panel.
  6. Nikon Coolpix E5700 Viewfinder Replacement: 6 단계, 이미지 1/1
    • Turn to the last side of the back panel.
    • Remove the Phillips screw below the eyepiece.
    • Remove the Phillips screw located above the speaker.
  7. Nikon Coolpix E5700 Viewfinder Replacement: 7 단계, 이미지 1/2 Nikon Coolpix E5700 Viewfinder Replacement: 7 단계, 이미지 2/2
    • Gently begin to remove the back panel.
    • Caution: There are two bundles of wires connecting the back panel to the camera. Be sure not to pull too hard and yank these out.
  8. Nikon Coolpix E5700 Viewfinder Replacement: 8 단계, 이미지 1/2 Nikon Coolpix E5700 Viewfinder Replacement: 8 단계, 이미지 2/2
    • Now gently unplug the two wires at the bottom of the panel.
  9. Nikon Coolpix E5700 Viewfinder Replacement, Top Cover: 9 단계, 이미지 1/1
    • Finish pulling away the back panel.
    • Turn the camera to its non-grip side.
    • Remove the Phillips screw located above the strap holder.
  10. Nikon Coolpix E5700 Viewfinder Replacement: 10 단계, 이미지 1/2 Nikon Coolpix E5700 Viewfinder Replacement: 10 단계, 이미지 2/2
    • Open the CF card slot.
    • Remove the Phillips screw near the top of the camera.
  11. Nikon Coolpix E5700 Viewfinder Replacement: 11 단계, 이미지 1/1
    • Turn to the front of the camera.
    • Lift up the corner of the grip pad nearest to the flash bulb.
    • Remove the Phillips screw underneath the grip pad.
  12. Nikon Coolpix E5700 Viewfinder Replacement: 12 단계, 이미지 1/2 Nikon Coolpix E5700 Viewfinder Replacement: 12 단계, 이미지 2/2
    • Lift up the flash bulb container.
    • Remove the two Phillips screws located near the base of the section.
  13. Nikon Coolpix E5700 Viewfinder Replacement: 13 단계, 이미지 1/2 Nikon Coolpix E5700 Viewfinder Replacement: 13 단계, 이미지 2/2
    • Open the battery compartment.
    • Remove the Phillips screw located at the bottom of the battery compartment.
  14. Nikon Coolpix E5700 Viewfinder Replacement: 14 단계, 이미지 1/1
    • Begin to lift the top cover from the rest of the camera.
    • Be careful when doing this because many wires are connecting the top piece to the camera. Pulling too hard may pull these wires out.
  15. Nikon Coolpix E5700 Viewfinder Replacement: 15 단계, 이미지 1/1
    • In order to pull the top panel without removing the flash unit. You must remove the flash top cover, taking away the screw under the bulb (see image). then gently remove the plastic top cover. IMPORTANT: discharge the condenser as soon as possible (the flash wires are now exposed, and dangerous ).
  16. Nikon Coolpix E5700 Viewfinder Replacement: 16 단계, 이미지 1/2 Nikon Coolpix E5700 Viewfinder Replacement: 16 단계, 이미지 2/2
    • Unplug the orange ribbon wire from the back of the camera.
    • Unplug the two blue ribbon wires from the back of the camera.
  17. Nikon Coolpix E5700 Viewfinder Replacement: 17 단계, 이미지 1/2 Nikon Coolpix E5700 Viewfinder Replacement: 17 단계, 이미지 2/2
    • Remove the Phillips screws on both sides of the flash bulb mount.
  18. Nikon Coolpix E5700 Viewfinder Replacement: 18 단계, 이미지 1/2 Nikon Coolpix E5700 Viewfinder Replacement: 18 단계, 이미지 2/2
    • Lift the top panel up and pull the flash bulb housing away from the rest of the top panel.
    • Note: The top panel will be difficult to separate from the flash bulb housing. Place your hands as shown in the picture and push upward with your thumb while holding the flash bulb housing stationary
  19. Nikon Coolpix E5700 Viewfinder Replacement: 19 단계, 이미지 1/1
    • Unplug the orange ribbon and the other wires and finish carefully removing the top panel.
  20. Nikon Coolpix E5700 Viewfinder Replacement, Viewfinder: 20 단계, 이미지 1/1
    • Remove the Phillips screws on either side of the viewfinder.
  21. Nikon Coolpix E5700 Viewfinder Replacement: 21 단계, 이미지 1/1
    • Unplug the red and black group of wires underneath the viewfinder.
  22. Nikon Coolpix E5700 Viewfinder Replacement: 22 단계, 이미지 1/3 Nikon Coolpix E5700 Viewfinder Replacement: 22 단계, 이미지 2/3 Nikon Coolpix E5700 Viewfinder Replacement: 22 단계, 이미지 3/3
    • Slowly remove the viewfinder from the body of the camera.
    • Unplug the orange ribbon wire from the body of the camera.
  23. Nikon Coolpix E5700 Viewfinder Replacement: 23 단계, 이미지 1/2 Nikon Coolpix E5700 Viewfinder Replacement: 23 단계, 이미지 2/2
    • Remove the black tape from the back of the viewfinder.
  24. Nikon Coolpix E5700 Viewfinder Replacement: 24 단계, 이미지 1/2 Nikon Coolpix E5700 Viewfinder Replacement: 24 단계, 이미지 2/2
    • Remove the white panel from the back of the viewfinder.
  25. Nikon Coolpix E5700 Viewfinder Replacement: 25 단계, 이미지 1/3 Nikon Coolpix E5700 Viewfinder Replacement: 25 단계, 이미지 2/3 Nikon Coolpix E5700 Viewfinder Replacement: 25 단계, 이미지 3/3
    • Remove the LCD screen from the viewfinder.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kyle Sitton
회원 가입일: 04/17/11
351 평판
안내서 7개 작성하였습니다
Cal Poly, Team 24-58, Amido Spring 2011 Cal Poly, Team 24-58, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G58
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 17
전체 시간: 3,548
