주요 콘텐츠로 건너뛰기
Nikon Coolpix L18 LCD Screen Replacement
필요한 것
  1. Nikon Coolpix L18 LCD Screen Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 LCD Screen Replacement: 2 단계, 이미지 1/2 Nikon Coolpix L18 LCD Screen Replacement: 2 단계, 이미지 2/2
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1/1
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
  6. Nikon Coolpix L18 LCD Screen Replacement: 6 단계, 이미지 1/1
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Nonny
회원 가입일: 10/11/10
219 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-23, Regan Fall 2010 Cal Poly, Team 9-23, Regan Fall 2010 회원
CPSU-REGAN-F10S9G23
4 회원들
안내서 10개 작성하였습니다
댓글 4개
Good work! Appreciate it.
Oasis World - 답글
I need a new LCD screen replacement. A link to buy a new one?
William Pullman - 답글
Where can I get a replacement LCD screen for a Nikon L18 camera?
I found one for my Nikon Coolpix L18 on eBay.
Mark Fraylick -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 7,056
