소개
In this guide, we will give you step-by-step instructions on how to detach the LCD screen so that it can be replaced or repaired.
필요한 것
Remove the tape on the right side of the LCD screen.
Gently lift the LCD screen from its base.
Be very careful not to touch the flash capacitor on far left when lifting the LCD!! It WILL shock you.
Getting the LCD ribbon back "in" is my problem -- hints or suggestions?
I can't get a feel for how the black clip holds the ribbon - insert the new one at an angle?
I practiced a few times with the "bad screen" and managed to figure this out. Unfortunately I can't explain how I did it... if some other person can explain how to make the ribbon connection/clip re-install more predictable I think it'd help anyone else who tries the repair.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 4개
Good work! Appreciate it.
I need a new LCD screen replacement. A link to buy a new one?
Where can I get a replacement LCD screen for a Nikon L18 camera?
I found one for my Nikon Coolpix L18 on eBay.
