주요 콘텐츠로 건너뛰기
Nikon Coolpix L18 LCD Screen Replacement
필요한 것
  1. Nikon Coolpix L18 LCD Screen Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 LCD Screen Replacement: 2 단계, 이미지 1/2 Nikon Coolpix L18 LCD Screen Replacement: 2 단계, 이미지 2/2
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1/1
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
    Be very careful not to touch the flash capacitor on far left when lifting the LCD!! It WILL shock you.
    Mark Fraylick - 답글
    Getting the LCD ribbon back "in" is my problem -- hints or suggestions?
    richardkujawa - 답글
    I can't get a feel for how the black clip holds the ribbon - insert the new one at an angle?
    richardkujawa - 답글
    I practiced a few times with the "bad screen" and managed to figure this out. Unfortunately I can't explain how I did it... if some other person can explain how to make the ribbon connection/clip re-install more predictable I think it'd help anyone else who tries the repair.
    richardkujawa - 답글
  6. Nikon Coolpix L18 LCD Screen Replacement: 6 단계, 이미지 1/1
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Nonny
회원 가입일: 10/11/10
219 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-23, Regan Fall 2010 Cal Poly, Team 9-23, Regan Fall 2010 회원
CPSU-REGAN-F10S9G23
4 회원들
안내서 10개 작성하였습니다
댓글 4개
Good work! Appreciate it.
Oasis World - 답글
I need a new LCD screen replacement. A link to buy a new one?
William Pullman - 답글
Where can I get a replacement LCD screen for a Nikon L18 camera?
I found one for my Nikon Coolpix L18 on eBay.
Mark Fraylick -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 7,056
