소개
This repair guide follows the back cover guide and requires the use of the spudger tool and Phillips screwdriver.
필요한 것
Remove the batteries from the battery compartment by sliding the white battery compartment switch up and then move the panel toward the right.
Carefully flip over the LCD screen onto its front. Pull the top of the LCD screen toward you keeping the bottom of it inside the camera.
다른 3명이 해당 안내서를 완성하였습니다.
