주요 콘텐츠로 건너뛰기
Nikon Coolpix L27 Screen Replacement
필요한 것
  1. Nikon Coolpix L27 Screen Replacement, Screen: 1 단계, 이미지 1/3 Nikon Coolpix L27 Screen Replacement, Screen: 1 단계, 이미지 2/3 Nikon Coolpix L27 Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Undo the latch at the bottom of the camera by pushing it to the side
    • Remove the batteries (and memory card if applicable)
  2. Nikon Coolpix L27 Screen Replacement: 2 단계, 이미지 1/2 Nikon Coolpix L27 Screen Replacement: 2 단계, 이미지 2/2
    • Remove the two 5 mm Phillips #000 screws from the left side.
  3. Nikon Coolpix L27 Screen Replacement: 3 단계, 이미지 1/3 Nikon Coolpix L27 Screen Replacement: 3 단계, 이미지 2/3 Nikon Coolpix L27 Screen Replacement: 3 단계, 이미지 3/3
    • Lift the cover labeled "A/V OUT" to expose a hidden screw.
    • Remove two 5 mm Phillips #000 screws from the bottom of the camera.
  4. Nikon Coolpix L27 Screen Replacement: 4 단계, 이미지 1/2 Nikon Coolpix L27 Screen Replacement: 4 단계, 이미지 2/2
    • Remove the two 5 mm Phillips #000 screws from the right side of the camera.
  5. Nikon Coolpix L27 Screen Replacement: 5 단계, 이미지 1/3 Nikon Coolpix L27 Screen Replacement: 5 단계, 이미지 2/3 Nikon Coolpix L27 Screen Replacement: 5 단계, 이미지 3/3
    • Carefully pry the back cover starting from the battery latch.
    • Once all sides are loose, lift the back cover up and off.
  6. Nikon Coolpix L27 Screen Replacement: 6 단계, 이미지 1/1
    • Carefully lift the LCD screen up towards the bottom of the camera.
    • The LCD is connected to a cable so don't pull it out yet.
  7. Nikon Coolpix L27 Screen Replacement: 7 단계, 이미지 1/1
    • Lightly push back the white switch holding in the screen cable
  8. Nikon Coolpix L27 Screen Replacement: 8 단계, 이미지 1/2 Nikon Coolpix L27 Screen Replacement: 8 단계, 이미지 2/2
    • Remove the cable from the camera.
    • Lift the screen out.
결론
Vishalpreet Sandhu
회원 가입일: 01/18/22
157 평판
안내서 1개 작성함
York University, Team R-25, Melo-Thaiss Winter 2022 York University, Team R-25, Melo-Thaiss Winter 2022 회원
YORK-MELO-THAISS-W22SRG25
1 회원
안내서 1개 작성하였습니다
댓글 한 개
would you know how to replace the little button battery just next to the screen, because the Lense is not retracting anymore?
Walter D. - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 49
전체 시간: 663
