주요 콘텐츠로 건너뛰기
Nikon Coolpix L320 LCD Replacement
필요한 것
  1. Nikon Coolpix L320 LCD Replacement, Batteries: 1 단계, 이미지 1/2 Nikon Coolpix L320 LCD Replacement, Batteries: 1 단계, 이미지 2/2
    • Flip the camera over to reveal the card/battery door.
    • Slide the button to the unlocked position and the door should pop open.
  2. Nikon Coolpix L320 LCD Replacement: 2 단계, 이미지 1/2 Nikon Coolpix L320 LCD Replacement: 2 단계, 이미지 2/2
    • Take out the old batteries.
    • Look at the yellow sticker inside of the the battery compartment. You'll see the symbol for the direction the new battery should face when replaced.
    • The “+” means to put the raised end facing up. The “-“ means to put the flat end up.
  3. Nikon Coolpix L320 LCD Replacement, LCD: 3 단계, 이미지 1/3 Nikon Coolpix L320 LCD Replacement, LCD: 3 단계, 이미지 2/3 Nikon Coolpix L320 LCD Replacement, LCD: 3 단계, 이미지 3/3
    • Use a JIS screwdriver to remove seven screws from the frame of camera.
  4. Nikon Coolpix L320 LCD Replacement: 4 단계, 이미지 1/1
    • Use an opening tool or spudger to separate the front and back of the camera.
  5. Nikon Coolpix L320 LCD Replacement: 5 단계, 이미지 1/1
    • Use a JIS screwdriver to remove the screws connecting the LCD to the motherboard.
  6. Nikon Coolpix L320 LCD Replacement: 6 단계, 이미지 1/1
    • Gently flip the LCD over to reveal a ribbon cable connected to the motherboard.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector. Then, you can safely pull the cable out.
    • Remove the LCD screen from the camera.
결론
MollyHenderson
회원 가입일: 03/20/23
293 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 5-6, Ramos Spring 2023 UMass Dartmouth, Team 5-6, Ramos Spring 2023 회원
UMASSD-RAMOS-S23S5G6
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 21
전체 시간: 147
