주요 콘텐츠로 건너뛰기
Nikon Coolpix L330 Back Housing Replacement
필요한 것
  1. Nikon Coolpix L330 Back Housing Replacement, Back Housing: 1 단계, 이미지 1/3 Nikon Coolpix L330 Back Housing Replacement, Back Housing: 1 단계, 이미지 2/3 Nikon Coolpix L330 Back Housing Replacement, Back Housing: 1 단계, 이미지 3/3
    • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
    • Two 1.5x2.5mm screws on the right side.
    • Two 1.5x2.5mm screws on the underside.
    • Two 1.5x2.5mm screw on the left side.
  2. Nikon Coolpix L330 Back Housing Replacement: 2 단계, 이미지 1/2 Nikon Coolpix L330 Back Housing Replacement: 2 단계, 이미지 2/2
    • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
    • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
    • Remove the back housing of the camera by lifting it directly up.
    • The back cover may be slightly tight, therefore more force may be needed to lift it up.
결론
Taibah
회원 가입일: 02/09/16
121 평판
안내서 1개 작성함
USF Tampa, Team 2-10, Cagle Spring 2016 USF Tampa, Team 2-10, Cagle Spring 2016 회원
USFT-CAGLE-S16S2G10
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 531
