주요 콘텐츠로 건너뛰기
Nikon Coolpix L340 Battery Replacement
  1. Nikon Coolpix L340 Battery Replacement, Battery: 1 단계, 이미지 1/2 Nikon Coolpix L340 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera
    • If the camera lens its pointing towards you, there should be a small lever on the right hand side
    • Take this lever and push it away from your body, while simultaneously pulling upwards
  2. Nikon Coolpix L340 Battery Replacement: 2 단계, 이미지 1/2 Nikon Coolpix L340 Battery Replacement: 2 단계, 이미지 2/2
    • Once you have pulled up, four batteries will appear underneith
    • Note how there are two batteries facing upwards (circled in red)
    • and two batteries facing downwards (circled in orange)
    • When the new batteries are placed back in the camera, they should be put back in this same orientation
  3. Nikon Coolpix L340 Battery Replacement: 3 단계, 이미지 1/1
    • Take out each of the batteries
  4. Nikon Coolpix L340 Battery Replacement: 4 단계, 이미지 1/1
    • When all of the batteries have been removed you should see four places for four new batteries to be inserted
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nikki Butts
회원 가입일: 03/04/16
179 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S3G3
4 회원들
안내서 8개 작성하였습니다
댓글 4개
Hi, I just replaced my Nikon Coolpix L340's batteries with new AAs and have followed all steps correctly but my camera is still saying 'battery exhausted' when I try turning it back on. Any ideas why it's not working?
Thank you!
Mia - 답글
The negative terminal must be raised like the Duracell Ultra. The Energizer MAX and other AAs have a FLAT negative terminal. The manual warns against them.
thestevelink -
No lever, only recessed button
ccpotts47 - 답글
thestevelink - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 21
30일 전: 101
전체 시간: 9,795
