주요 콘텐츠로 건너뛰기
Nikon Coolpix L340 Buttons Replacement
필요한 것
  1. Nikon Coolpix L340 Buttons Replacement, Buttons: 1 단계, 이미지 1/1
    • Remove the 5 mm Phillips #000 screw located on the upper left side of the camera
    • Remove the 5 mm Phillips #000 screw located on the lower left side of the camera
  2. Nikon Coolpix L340 Buttons Replacement: 2 단계, 이미지 1/1
    • Remove the 5 mm Phillips #000 screw from the upper right side of the camera.
    • Remove the 5 mm Phillips #000 screw from the lower right side of the camera.
  3. Nikon Coolpix L340 Buttons Replacement: 3 단계, 이미지 1/1
    • Remove the 5 mm Phillips #000 screw from the bottom left of the camera.
    • Remove the 5 mm Phillips #000 screw from the left-center of the bottom of the camera.
    • Remove the 5 mm Phillips #000 screw from the center of the bottom of the camera.
  4. Nikon Coolpix L340 Buttons Replacement: 4 단계, 이미지 1/1
    • Remove back cover of the camera.
  5. Nikon Coolpix L340 Buttons Replacement: 5 단계, 이미지 1/1
    • Push buttons out of the back of the cover.
결론
Robert Estrella
회원 가입일: 03/04/16
101 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S3G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 19
전체 시간: 1,227
