주요 콘텐츠로 건너뛰기
Nikon Coolpix L340 LCD Screen Replacement
필요한 것
  1. Nikon Coolpix L340 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/3 Nikon Coolpix L340 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2/3 Nikon Coolpix L340 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3/3
    • Remove two 5 mm Philips #000 screws on the left hand side of the camera located on the side where the batteries are inserted.
    • Remove two 5 mm Philips #000 screws on the bottom of the camera.
    • Remove two 5 mm Philips #000 screws on the left hand side of the camera located near the power button.
  2. Nikon Coolpix L340 LCD Screen Replacement: 2 단계, 이미지 1/3 Nikon Coolpix L340 LCD Screen Replacement: 2 단계, 이미지 2/3 Nikon Coolpix L340 LCD Screen Replacement: 2 단계, 이미지 3/3
    • After removing all six screws, you should be able to remove the plastic cover that holds the buttons and keeps the LCD screen in place.
    • Once you remove the back cover you should be able to access the bracket piece that holds the LCD screen.
    • Notice that the LCD screen is connected to the motherboard via a very fragile circuit piece, be very care removing the old and attaching the new LCD screen so that nothing else gets broken.
  3. Nikon Coolpix L340 LCD Screen Replacement: 3 단계, 이미지 1/2 Nikon Coolpix L340 LCD Screen Replacement: 3 단계, 이미지 2/2
    • In order to get to the motherboard to disconnect the old LCD screen, you need to remove three 5 mm Phillips #000 screws that connect the bracket piece to the motherboard.
  4. Nikon Coolpix L340 LCD Screen Replacement: 4 단계, 이미지 1/2 Nikon Coolpix L340 LCD Screen Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • To remove the old LCD screen from the motherboard, there is an off-white ribbon on the motherboard that, the thin black ZIF (Zero Insertion Force) connector that needs to be lifted up so that the circuit piece connected to the LCD screen can be pulled out.
    • Using tweezers or fingers gently disconnect the LCD screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joseph Harrington
회원 가입일: 03/04/16
143 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S3G3
4 회원들
안내서 8개 작성하였습니다
댓글 2개
Is there a plastic cover as part of the rear cover on the L340? Trying to determine what exactly is cracked
megblackwell - 답글
Very helpful. Thanks
Haibin Zheng - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 13
전체 시간: 2,434
