소개
Follow this guide to replace a cracked or not working LCD screen for the Coolpix L340.
필요한 것
Remove two 5 mm Philips #000 screws on the left hand side of the camera located on the side where the batteries are inserted.
Remove two 5 mm Philips #000 screws on the bottom of the camera.
Remove two 5 mm Philips #000 screws on the left hand side of the camera located near the power button.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Is there a plastic cover as part of the rear cover on the L340? Trying to determine what exactly is cracked
Very helpful. Thanks
