주요 콘텐츠로 건너뛰기
Nikon Coolpix L340 Memory Card Replacement
  1. Nikon Coolpix L340 Memory Card Replacement, Memory Card: 1 단계, 이미지 1/2 Nikon Coolpix L340 Memory Card Replacement, Memory Card: 1 단계, 이미지 2/2
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera.
    • If the camera lens is pointing towards you, there should be a small lever on the right hand side.
    • Take this lever and push it away from your body, while simultaneously pulling upwards.
  2. Nikon Coolpix L340 Memory Card Replacement: 2 단계, 이미지 1/1
    • Gently press down on the memory card until you hear a click, then release the pressure to eject the card and slowly pull it upwards out of the slot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kelly Kryzak
회원 가입일: 04/12/16
140 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S3G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 24
전체 시간: 1,472
