소개
Follow this step by step guide for memory card replacement.
Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera.
If the camera lens is pointing towards you, there should be a small lever on the right hand side.
Take this lever and push it away from your body, while simultaneously pulling upwards.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
