주요 콘텐츠로 건너뛰기
Nikon Coolpix L610 Battery and Memory Card Replacement
  1. Nikon Coolpix L610 Battery and Memory Card Replacement, Battery and Memory Card: 1 단계, 이미지 1/1
    • The batteries are located on the bottom of the device on the right hand side. To open the compartment press the button in and slide it towards you and pull the door open.
  2. Nikon Coolpix L610 Battery and Memory Card Replacement: 2 단계, 이미지 1/1
    • The memory card is located next to the batteries. To remove the memory card press it in and it should pop out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeremy
회원 가입일: 01/21/15
1,027 평판
안내서 5개 작성하였습니다
USF Tampa, Team 9-4, Brown Winter 2015 USF Tampa, Team 9-4, Brown Winter 2015 회원
USFT-BROWN-W15S9G4
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
I need help - my Coolpix L610 battery door will not close and lock.
gmurphree1@aol.com - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 22
전체 시간: 2,180
