주요 콘텐츠로 건너뛰기
Nikon Coolpix L610 Camera Lens Replacement
필요한 것
  1. Nikon Coolpix L610 Camera Lens Replacement, Plastic Cover: 1 단계, 이미지 2개 중 1개 Nikon Coolpix L610 Camera Lens Replacement, Plastic Cover: 1 단계, 이미지 2개 중 2개
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
  2. Nikon Coolpix L610 Camera Lens Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
  3. Nikon Coolpix L610 Camera Lens Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
  4. Nikon Coolpix L610 Camera Lens Replacement: 4 단계, 이미지 3개 중 1개 Nikon Coolpix L610 Camera Lens Replacement: 4 단계, 이미지 3개 중 2개 Nikon Coolpix L610 Camera Lens Replacement: 4 단계, 이미지 3개 중 3개
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
  5. Nikon Coolpix L610 Camera Lens Replacement, Control Panel: 5 단계, 이미지 3개 중 1개 Nikon Coolpix L610 Camera Lens Replacement, Control Panel: 5 단계, 이미지 3개 중 2개 Nikon Coolpix L610 Camera Lens Replacement, Control Panel: 5 단계, 이미지 3개 중 3개
    • Carefully unscrew and remove the top and bottom (2.25 mm) screws from the control panel.
    • Carefully unscrew and remove the middle (3.20 mm) screws from the control panel.
  6. Nikon Coolpix L610 Camera Lens Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully remove the ribbon connecting the control panel to the camera. The latch can be removed by sliding it down and pulling the ribbon down.
  7. Nikon Coolpix L610 Camera Lens Replacement, Removing the screen: 7 단계, 이미지 1개 중 1개
    • Using a prying tool, carefully lift up the LCD screen but do NOT pull it off.
  8. Nikon Coolpix L610 Camera Lens Replacement, Removing the LCD Screen Ribbon: 8 단계, 이미지 2개 중 1개 Nikon Coolpix L610 Camera Lens Replacement, Removing the LCD Screen Ribbon: 8 단계, 이미지 2개 중 2개
    • While the LCD screen is loose and unattached, there is a latch that is holding the ribbon in place. Slide the latch down and pull the ribbon out.
  9. Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: 9 단계, 이미지 3개 중 1개 Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: 9 단계, 이미지 3개 중 2개 Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: 9 단계, 이미지 3개 중 3개
    • Remove the 6 (3.70 mm) screws on the metal cover. Two of those screws are covered by black plastic covers.
    • After removing the screws the panel should come off and will look like the final image.
    • Be careful of the red and black wires on the top. If the flash is charged you could get a mild shock.
  10. Nikon Coolpix L610 Camera Lens Replacement: 10 단계, 이미지 1개 중 1개
    • Unplug the two ribbons for the lens. There will be latch that will need to be slid down. After loosening the latch, the ribbon should be able to be easily pulled out.
  11. Nikon Coolpix L610 Camera Lens Replacement: 11 단계, 이미지 2개 중 1개 Nikon Coolpix L610 Camera Lens Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the 3 (3.10 mm) screws that are located on the back of the lens cover.
  12. Nikon Coolpix L610 Camera Lens Replacement: 12 단계, 이미지 3개 중 1개 Nikon Coolpix L610 Camera Lens Replacement: 12 단계, 이미지 3개 중 2개 Nikon Coolpix L610 Camera Lens Replacement: 12 단계, 이미지 3개 중 3개
    • There are two lens covers that will fall out after removing the back lens plate.
    • Remove the 6 (4.35 mm) screws surrounding the lens.
    • There are 2 more (3.70 mm) screws covered by a small black square located. Remove the black squares and proceed to unscrewing these final screws.
    • Remove the lens. It should just be free to pull it out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jeremy
회원 가입일: 01/21/15
1,099 평판
안내서 5개를 작성함
USF Tampa, Team 9-4, Brown Winter 2015 USF Tampa, Team 9-4, Brown Winter 2015 회원
USFT-BROWN-W15S9G4
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 2,714
