주요 콘텐츠로 건너뛰기
Nikon Coolpix L610 Control Panel Replacement
필요한 것
  1. Nikon Coolpix L610 Control Panel Replacement, Plastic Cover: 1 단계, 이미지 2개 중 1개 Nikon Coolpix L610 Control Panel Replacement, Plastic Cover: 1 단계, 이미지 2개 중 2개
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
  2. Nikon Coolpix L610 Control Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
  3. Nikon Coolpix L610 Control Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
  4. Nikon Coolpix L610 Control Panel Replacement: 4 단계, 이미지 3개 중 1개 Nikon Coolpix L610 Control Panel Replacement: 4 단계, 이미지 3개 중 2개 Nikon Coolpix L610 Control Panel Replacement: 4 단계, 이미지 3개 중 3개
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
  5. Nikon Coolpix L610 Control Panel Replacement, Control Panel: 5 단계, 이미지 3개 중 1개 Nikon Coolpix L610 Control Panel Replacement, Control Panel: 5 단계, 이미지 3개 중 2개 Nikon Coolpix L610 Control Panel Replacement, Control Panel: 5 단계, 이미지 3개 중 3개
    • Carefully unscrew and remove the top and bottom (2.25 mm) screws from the control panel.
    • Carefully unscrew and remove the middle (3.20 mm) screws from the control panel.
  6. Nikon Coolpix L610 Control Panel Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully remove the ribbon connecting the control panel to the camera. The latch can be removed by sliding it down and pulling the ribbon down.
결론
작성자
3다른 기여자 명과 함께
Jeremy
회원 가입일: 01/21/15
1,099 평판
안내서 5개를 작성함
USF Tampa, Team 9-4, Brown Winter 2015 USF Tampa, Team 9-4, Brown Winter 2015 회원
USFT-BROWN-W15S9G4
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 687
