주요 콘텐츠로 건너뛰기
Nikon Coolpix L610 Power/Shutter Button Assembly Replacement
필요한 것
  1. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement, Plastic Cover: 1 단계, 이미지 1/2 Nikon Coolpix L610 Power/Shutter Button Assembly Replacement, Plastic Cover: 1 단계, 이미지 2/2
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
  2. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: 2 단계, 이미지 1/1
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
  3. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: 3 단계, 이미지 1/1
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
  4. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: 4 단계, 이미지 1/3 Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: 4 단계, 이미지 2/3 Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: 4 단계, 이미지 3/3
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
  5. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement, Power/Shuttter Button Assembly: 5 단계, 이미지 1/1
    • Remove the panel containing the power and shutter button.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Miragliotta
회원 가입일: 01/21/15
167 평판
안내서 1개 작성함
USF Tampa, Team 9-4, Brown Winter 2015 USF Tampa, Team 9-4, Brown Winter 2015 회원
USFT-BROWN-W15S9G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 15
전체 시간: 739
