주요 콘텐츠로 건너뛰기
Nikon Coolpix L810 Flash Replacement
필요한 것
  1. Nikon Coolpix L810 Flash Replacement, Flash: 1 단계, 이미지 1/1
    • Remove two 5 mm Phillips #000 screws below the flash component.
    • In order to complete this step the flash must be open. To open the flash press the button located above the lens on the leftward side of the camera.
  2. Nikon Coolpix L810 Flash Replacement: 2 단계, 이미지 1/1
    • Use blue plastic opening tool to pry open the casing for the flash.
  3. Nikon Coolpix L810 Flash Replacement: 3 단계, 이미지 1/1
    • Remove the plastic casing surrounding the flash.
  4. Nikon Coolpix L810 Flash Replacement: 4 단계, 이미지 1/2 Nikon Coolpix L810 Flash Replacement: 4 단계, 이미지 2/2
    • Pull the wires connecting the flash out of the camera.
  5. Nikon Coolpix L810 Flash Replacement: 5 단계, 이미지 1/3 Nikon Coolpix L810 Flash Replacement: 5 단계, 이미지 2/3 Nikon Coolpix L810 Flash Replacement: 5 단계, 이미지 3/3
    • Unsolder the wires that connect the flash component.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Emilio Mena
회원 가입일: 01/14/15
776 평판
안내서 4개 작성하였습니다
UW Tacoma, Team 3-1, Rose Winter 2015 UW Tacoma, Team 3-1, Rose Winter 2015 회원
UWT-ROSE-W15S3G1
4 회원들
안내서 8개 작성하였습니다
댓글 4개
It's not a comment, but where did you obtain the replacement flashbulb?
hgdddee - 답글
the heading says no parts required. but I think i need a new flashbulb? any idea what the type is or where to buy it ?
wildstreaksavannahs - 답글
I can't get into bulb
Szabolcs Demeter - 답글
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a> n advmd vdsm vs ds m
nirik - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 2,209
