주요 콘텐츠로 건너뛰기
Nikon Coolpix L810 LCD Replacement
필요한 것
  1. Nikon Coolpix L810 LCD Replacement, LCD: 1 단계, 이미지 1/2 Nikon Coolpix L810 LCD Replacement, LCD: 1 단계, 이미지 2/2
    • Remove two 5 mm Phillips #000 screws on the right hand side of the camera located near the power button.
    • Use of precision tweezers to help remove loosened screws is suggested.
  2. Nikon Coolpix L810 LCD Replacement: 2 단계, 이미지 1/2 Nikon Coolpix L810 LCD Replacement: 2 단계, 이미지 2/2
    • Remove two 5 mm Phillips #000 screws near the audio/video inputs on the opposite side near the flash component.
  3. Nikon Coolpix L810 LCD Replacement: 3 단계, 이미지 1/2 Nikon Coolpix L810 LCD Replacement: 3 단계, 이미지 2/2
    • Remove three 5 mm Phillips #000 screws on the bottom end of the camera.
  4. Nikon Coolpix L810 LCD Replacement: 4 단계, 이미지 1/1
    • Carefully detach the back side of the camera by lifting both ends, with moderate force wobble until loosened enough to remove.
  5. Nikon Coolpix L810 LCD Replacement: 5 단계, 이미지 1/2 Nikon Coolpix L810 LCD Replacement: 5 단계, 이미지 2/2
    • With the LCD screen facing towards you, flip the screen to the right.
  6. Nikon Coolpix L810 LCD Replacement: 6 단계, 이미지 1/3 Nikon Coolpix L810 LCD Replacement: 6 단계, 이미지 2/3 Nikon Coolpix L810 LCD Replacement: 6 단계, 이미지 3/3
    • Remove three 5 mm Phillips #000 screws located on the bracket.
    • Hold the camera with the lens facing downward to prevent the bracket from falling off once all screws are removed.
  7. Nikon Coolpix L810 LCD Replacement: 7 단계, 이미지 1/2 Nikon Coolpix L810 LCD Replacement: 7 단계, 이미지 2/2
    • Disconnect the ribbons that connect the LCD screen to the camera gently using precision tweezers or fingers.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Emilio Mena
회원 가입일: 01/14/15
752 평판
안내서 4개 작성하였습니다
UW Tacoma, Team 3-1, Rose Winter 2015 UW Tacoma, Team 3-1, Rose Winter 2015 회원
UWT-ROSE-W15S3G1
4 회원들
안내서 8개 작성하였습니다
댓글 2개
I love ifixit instructions so much more than youtube. These are so easy and straightfoward and I love how screw sizes are carefully specified.
Susan - 답글
Congratulations! Perfect lesson !
I need HELP presentation abowt desassembler / remove motherboard and other parts to repair the lenz move mechanism. Unfortunately NIKON left Brazil and the resident Suport tecnician besides not being good, stay in quarentine (corona virus)! Special Thanks for you help! Best regards
ramos.eng - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 18
전체 시간: 2,603
