주요 콘텐츠로 건너뛰기
Nikon Coolpix L810 Motherboard Replacement
필요한 것
  1. Nikon Coolpix L810 Motherboard Replacement, LCD: 1 단계, 이미지 1/2 Nikon Coolpix L810 Motherboard Replacement, LCD: 1 단계, 이미지 2/2
    • Remove two 5 mm Phillips #000 screws on the right hand side of the camera located near the power button.
    • Use of precision tweezers to help remove loosened screws is suggested.
  2. Nikon Coolpix L810 Motherboard Replacement: 2 단계, 이미지 1/2 Nikon Coolpix L810 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove two 5 mm Phillips #000 screws near the audio/video inputs on the opposite side near the flash component.
  3. Nikon Coolpix L810 Motherboard Replacement: 3 단계, 이미지 1/2 Nikon Coolpix L810 Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove three 5 mm Phillips #000 screws on the bottom end of the camera.
  4. Nikon Coolpix L810 Motherboard Replacement: 4 단계, 이미지 1/1
    • Carefully detach the back side of the camera by lifting both ends, with moderate force wobble until loosened enough to remove.
  5. Nikon Coolpix L810 Motherboard Replacement: 5 단계, 이미지 1/2 Nikon Coolpix L810 Motherboard Replacement: 5 단계, 이미지 2/2
    • With the LCD screen facing towards you, flip the screen to the right.
  6. Nikon Coolpix L810 Motherboard Replacement: 6 단계, 이미지 1/3 Nikon Coolpix L810 Motherboard Replacement: 6 단계, 이미지 2/3 Nikon Coolpix L810 Motherboard Replacement: 6 단계, 이미지 3/3
    • Remove three 5 mm Phillips #000 screws located on the bracket.
    • Hold the camera with the lens facing downward to prevent the bracket from falling off once all screws are removed.
  7. Nikon Coolpix L810 Motherboard Replacement: 7 단계, 이미지 1/2 Nikon Coolpix L810 Motherboard Replacement: 7 단계, 이미지 2/2
    • Disconnect the ribbons that connect the LCD screen to the camera gently using precision tweezers or fingers.
  8. Nikon Coolpix L810 Motherboard Replacement, Motherboard: 8 단계, 이미지 1/3 Nikon Coolpix L810 Motherboard Replacement, Motherboard: 8 단계, 이미지 2/3 Nikon Coolpix L810 Motherboard Replacement, Motherboard: 8 단계, 이미지 3/3
    • Remove three 5 mm Phillips #000 screws bordering the motherboard.
  9. Nikon Coolpix L810 Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove the plastic component located directly behind the flash from its rubberized holder.
  10. Nikon Coolpix L810 Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the electric tape covering the wires.
  11. Nikon Coolpix L810 Motherboard Replacement: 11 단계, 이미지 1/3 Nikon Coolpix L810 Motherboard Replacement: 11 단계, 이미지 2/3 Nikon Coolpix L810 Motherboard Replacement: 11 단계, 이미지 3/3
    • Unsolder all the wires that are on the top of the motherboard near the flash component.
  12. Nikon Coolpix L810 Motherboard Replacement: 12 단계, 이미지 1/1
    • Unsolder the wires on the bottom end of the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Emilio Mena
회원 가입일: 01/14/15
752 평판
안내서 4개 작성하였습니다
UW Tacoma, Team 3-1, Rose Winter 2015 UW Tacoma, Team 3-1, Rose Winter 2015 회원
UWT-ROSE-W15S3G1
4 회원들
안내서 8개 작성하였습니다
댓글 4개
The guide is incomplete! Do not try to remove the mobo for it is soldered to some other tiny board under the on/off switch. Trying to remove the mobo after just unscrewing it, may guide to certain and permanent destruction of both PCBs!!!
symeonleriou - 답글
any clue how to get tiny mobo out with mobo after taking screw out of tiny one at on/off switch?
jon baker - 답글
This guide should be for beginners, Mr. Symeon Leriou, and you will not only write "Mobo", but also motherboard or Mainboard or Hauptplatine (deutsch)
But I agree with you that it is not complete.
The motherboard is soldered to the on / off board (power supply for the batteries).
Soldering again is almost impossible ...
lothar4460 - 답글
Exactly! The guide is GOOD but it is incomplete!
The solder removal is insufficient to release de motherboard.
How to do it?
ramos.eng - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 26
전체 시간: 3,091
