주요 콘텐츠로 건너뛰기
Nikon Coolpix L820 Device Ports Replacement
필요한 것
  1. Nikon Coolpix L820 Device Ports Replacement, Settings Buttons: 1 단계, 이미지 1/3 Nikon Coolpix L820 Device Ports Replacement, Settings Buttons: 1 단계, 이미지 2/3 Nikon Coolpix L820 Device Ports Replacement, Settings Buttons: 1 단계, 이미지 3/3
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
  2. Nikon Coolpix L820 Device Ports Replacement: 2 단계, 이미지 1/2 Nikon Coolpix L820 Device Ports Replacement: 2 단계, 이미지 2/2
    • Remove the front top Phillips screw with the screwdriver.
    • Open the empty battery slot on the bottom of the camera, revealing four additional screws.
    • Unscrew the four Phillips screws with the screwdriver.
  3. Nikon Coolpix L820 Device Ports Replacement: 3 단계, 이미지 1/3 Nikon Coolpix L820 Device Ports Replacement: 3 단계, 이미지 2/3 Nikon Coolpix L820 Device Ports Replacement: 3 단계, 이미지 3/3
    • Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly.
    • Be sure to only apply pressure to the casing panels and not the sensitive internal electronics.
    • Once the rear housing is separated, the settings buttons will be accessible for replacement.
  4. Nikon Coolpix L820 Device Ports Replacement, LCD screen: 4 단계, 이미지 1/3 Nikon Coolpix L820 Device Ports Replacement, LCD screen: 4 단계, 이미지 2/3 Nikon Coolpix L820 Device Ports Replacement, LCD screen: 4 단계, 이미지 3/3
    • Remove the front casing to expose the LCD screen and wires.
    • Do not damage the exposed wires.
  5. Nikon Coolpix L820 Device Ports Replacement: 5 단계, 이미지 1/3 Nikon Coolpix L820 Device Ports Replacement: 5 단계, 이미지 2/3 Nikon Coolpix L820 Device Ports Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using the tweezers, lift the hinges connecting the two ribbon wires to the camera.
  6. Nikon Coolpix L820 Device Ports Replacement: 6 단계, 이미지 1/2 Nikon Coolpix L820 Device Ports Replacement: 6 단계, 이미지 2/2
    • Once the flexible ribbon wires are disconnected, remove the LCD screen.
  7. Nikon Coolpix L820 Device Ports Replacement, Device Ports: 7 단계, 이미지 1/1
    • Begin by removing these five screws
  8. Nikon Coolpix L820 Device Ports Replacement: 8 단계, 이미지 1/1
    • From there, the panel covering the motherboard can be removed.
  9. Nikon Coolpix L820 Device Ports Replacement: 9 단계, 이미지 1/2 Nikon Coolpix L820 Device Ports Replacement: 9 단계, 이미지 2/2
    • Using the pointed end of the spudger, lift the hinges that secure these four flex circuits.
  10. Nikon Coolpix L820 Device Ports Replacement: 10 단계, 이미지 1/2 Nikon Coolpix L820 Device Ports Replacement: 10 단계, 이미지 2/2
    • Once the flex circuits are removed, the motherboard can be lifted and the device can be accessed for replacement.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Marc
회원 가입일: 03/23/15
430 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-4, Miles Spring 2015 UMass Dartmouth, Team 1-4, Miles Spring 2015 회원
UMASSD-MILES-S15S1G4
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
Could you explain how the power button is changed? Thank you!!
minigalinda - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 18
전체 시간: 1,836
