주요 콘텐츠로 건너뛰기
Nikon Coolpix L820 Settings Buttons Replacement
필요한 것
  1. Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: 1 단계, 이미지 1/3 Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: 1 단계, 이미지 2/3 Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: 1 단계, 이미지 3/3
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
  2. Nikon Coolpix L820 Settings Buttons Replacement: 2 단계, 이미지 1/2 Nikon Coolpix L820 Settings Buttons Replacement: 2 단계, 이미지 2/2
    • Remove the front top Phillips screw with the screwdriver.
    • Open the empty battery slot on the bottom of the camera, revealing four additional screws.
    • Unscrew the four Phillips screws with the screwdriver.
  3. Nikon Coolpix L820 Settings Buttons Replacement: 3 단계, 이미지 1/3 Nikon Coolpix L820 Settings Buttons Replacement: 3 단계, 이미지 2/3 Nikon Coolpix L820 Settings Buttons Replacement: 3 단계, 이미지 3/3
    • Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly.
    • Be sure to only apply pressure to the casing panels and not the sensitive internal electronics.
    • Once the rear housing is separated, the settings buttons will be accessible for replacement.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Marc
회원 가입일: 03/23/15
430 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-4, Miles Spring 2015 UMass Dartmouth, Team 1-4, Miles Spring 2015 회원
UMASSD-MILES-S15S1G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,266
