주요 콘텐츠로 건너뛰기
Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement
필요한 것
  1. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement, Back Casing: 1 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to unscrew the two 3.0mm Phillips screws located on the side of the camera with the HDMI port.
    • The HDMI port side will be on the left if you are looking at the back of the camera with the LCD monitor.
    • One screw is located under the gray flap.
  2. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: 2 단계, 이미지 1/1
    • Unscrew the five 3.0mm Phillips #000 screws that are located on the bottom side of the camera.
  3. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: 3 단계, 이미지 1/1
    • Unscrew the 4.0mm Phillips #000 screw located underneath the grey flap on the side of the camera with the "DC IN 5.0 V" marker.
    • This will be on the right if you are looking at the back LCD monitor side.
    • Unscrew the exposed 3.0mm Phillips #000 screw on the same side.
  4. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: 4 단계, 이미지 1/1
    • Press the flash button to open the flash component.
    • Remove the 3.0mm Phillips #000 screw located directly in-between the two arms.
  5. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: 5 단계, 이미지 1/1
    • Open the LCD monitor to reveal two 2.0mm Phillips screws.
    • Remove the 2.0mm Phillips #000 screws.
  6. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: 6 단계, 이미지 1/2 Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: 6 단계, 이미지 2/2
    • Make sure to open the plastic grey flaps on either side of the camera before proceeding with this step.
    • Insert a plastic opening tool between the back and front surface components of the camera.
    • Wiggle the plastic opening tool backwards and forwards along the top edge until the back surface comes off.
    • Remove the back casing gently to not damage the LCD ribbon connector or inner camera components.
  7. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: 7 단계, 이미지 1/2 Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: 7 단계, 이미지 2/2
    • Gently pull the LCD ribbon connector up to allow the back casing to be completely removed.
  8. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement, LCD Connecting Arm: 8 단계, 이미지 1/1
    • On the inside of the back cover, remove the two 2.0mm Phillips screws surrounding the connecting cable.
  9. Nikon Coolpix L830 LCD Monitor Connecting Arm Replacement: 9 단계, 이미지 1/1
    • Gently pull the ribbon connector in order to remove the complete LCD Monitor Connecting Arm.
결론
Alex Delony
회원 가입일: 11/01/16
184 평판
안내서 1개 작성함
Baylor, Team 4-4, Williams Fall 2016 Baylor, Team 4-4, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 505
