주요 콘텐츠로 건너뛰기
소개
This guide outlines the steps required to replace the LCD screen. Some parts can be delicate, so care is required when handling this replacement.
부품
지정된 부품이 없습니다.
  1. Extend the screen by grasping the screen and pulling it out.
    • Extend the screen by grasping the screen and pulling it out.
  2. Unscrew the four black, 4mm Phillip #000 screws on the corners of the back case of the screen.
    • Unscrew the four black, 4mm Phillip #000 screws on the corners of the back case of the screen.
    • Unscrew the two black, 2mm Phillips #000 screws on the case of the hinge. (The hinge connects the screen to the body of the camera.)
  3. PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
    PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
  4. Remove the top-half case of the hinge by lifting it off. Remove the bottom-half case of the hinge by lifting it off.
    • Remove the top-half case of the hinge by lifting it off.
    • Remove the bottom-half case of the hinge by lifting it off.
  5. Pry the back case off of the screen with a metal spludger by slipping the spludger in between the front and back halves of the screen's case and wiggling the spludger forwards and backwards.
    • Pry the back case off of the screen with a metal spludger by slipping the spludger in between the front and back halves of the screen's case and wiggling the spludger forwards and backwards.
  6. The front cover comes off easily once the back cover is removed in Step 4.
    • The front cover comes off easily once the back cover is removed in Step 4.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Abraham Lozano
회원 가입일: 2016년 04월 11일
568 평판
안내서 4개 작성하였습니다
Cal Poly, Team 1-11, Maness Spring 2016 Cal Poly, Team 1-11, Maness Spring 2016 회원
CPSU-MANESS-S16S1G11
4 회원들
안내서 5개 작성하였습니다
Where would you suggest I buy a replacement screen?
leinbergerc - 답글
Yours must be different than mine,. mine required a separation of a sticky piece from around the screen and then getting it back on the new one in almost perfect alignment as you find out when you start putting it back together. I used a prying tool a very small Phillips screwdriver and a very small torx tool, all of which came in the kit I ordered from easyworldwidetrading (Hong Kong) (ebay) for $64.99 no. 302013683286, but make sure yours is the same Camera, good Luck
Michael Crawford - 답글
PS: Be very careful, the piece's are cheap plastic and will break... Now I gotta find the outside piece... ugh
My LCD screen shows what I am taking a picture of but when I hit the picture viewer button the screen goes black. So do I need to replace the LCD screen or do you think it would be something else?
Megan Norman - 답글
My screen is showing a grainy pic especially red I have tried all I can think off. It goes when I turn color right down but leaves screen looking black and white. I know there’s an easy fix but can’t seem to find it. Any help pls
Harris Nnadi - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 38
전체 시간: 2,859
