소개
This guide outlines the steps required to replace the LCD screen. Some parts can be delicate, so care is required when handling this replacement.
필요한 것
다른 5명이 해당 안내서를 완성하였습니다.
댓글 9개
Where would you suggest I buy a replacement screen?
Yours must be different than mine,. mine required a separation of a sticky piece from around the screen and then getting it back on the new one in almost perfect alignment as you find out when you start putting it back together. I used a prying tool a very small Phillips screwdriver and a very small torx tool, all of which came in the kit I ordered from easyworldwidetrading (Hong Kong) (ebay) for $64.99 no. 302013683286, but make sure yours is the same Camera, good Luck
PS: Be very careful, the piece's are cheap plastic and will break... Now I gotta find the outside piece... ugh
My LCD screen shows what I am taking a picture of but when I hit the picture viewer button the screen goes black. So do I need to replace the LCD screen or do you think it would be something else?
My screen is showing a grainy pic especially red I have tried all I can think off. It goes when I turn color right down but leaves screen looking black and white. I know there’s an easy fix but can’t seem to find it. Any help pls
I haven't seen you unplug the ribbon cable and replace the slide play, you stopped in the middle of the repair, what's the point?
lothar4460 - 답글
My dog ate the screen. Do I absolutely need it, or can I remove it and just use the camera for video without the screen? I have a new Nikon for pictures, so don’t necessarily want to invest in this, but it is great for video clips while I take stills. Any suggestions would be appreciated!
How can I find a replacement part for the screen case bc my l840 display frame is broken on all 4 screws and I need a new one asap bc I love photography taking pics of cute hummingbirds and amazing cars and trucks. But yea I tried everything I could to try and find one at like Ebay Walmart best buy target and none can help me fix it
Hello. I need the front edge plastic cover. The front part of the screen case.
Where can I buy it?
