주요 콘텐츠로 건너뛰기
Nikon Coolpix L840 Lanyard Ring Replacement
필요한 것
  1. Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: 1 단계, 이미지 1/3 Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: 1 단계, 이미지 2/3 Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: 1 단계, 이미지 3/3
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Lanyard Ring Replacement: 2 단계, 이미지 1/1
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Lanyard Ring Replacement: 3 단계, 이미지 1/2 Nikon Coolpix L840 Lanyard Ring Replacement: 3 단계, 이미지 2/2
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
  4. Nikon Coolpix L840 Lanyard Ring Replacement, Lanyard Ring: 4 단계, 이미지 1/2 Nikon Coolpix L840 Lanyard Ring Replacement, Lanyard Ring: 4 단계, 이미지 2/2
    • Identify lanyard ring.
    • Unscrew the 4 mm black screw with a Philips 000.
  5. Nikon Coolpix L840 Lanyard Ring Replacement: 5 단계, 이미지 1/2 Nikon Coolpix L840 Lanyard Ring Replacement: 5 단계, 이미지 2/2
    • Insert a metal spludger (or another sturdy tool with a thin tip) into the hole of the lanyard ring and lift the ring upwards and out of the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Abraham Lozano
회원 가입일: 04/11/16
595 평판
안내서 4개 작성하였습니다
Cal Poly, Team 1-11, Maness Spring 2016 Cal Poly, Team 1-11, Maness Spring 2016 회원
CPSU-MANESS-S16S1G11
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 623
