주요 콘텐츠로 건너뛰기
Nikon Coolpix L840 Motherboard Replacement
필요한 것
  1. Nikon Coolpix L840 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Nikon Coolpix L840 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Nikon Coolpix L840 Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Motherboard Replacement: 2 단계, 이미지 1/1
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Motherboard Replacement: 3 단계, 이미지 1/2 Nikon Coolpix L840 Motherboard Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Abraham Lozano
회원 가입일: 04/11/16
595 평판
안내서 4개 작성하였습니다
Cal Poly, Team 1-11, Maness Spring 2016 Cal Poly, Team 1-11, Maness Spring 2016 회원
CPSU-MANESS-S16S1G11
4 회원들
안내서 10개 작성하였습니다
댓글 2개
I was trying to find how to replace the CCD lens sensor on the Nikon Coolpix L840
waynelguyton - 답글
My camera display will work for a bit, but then goes off. Subsequent efforts to start it yield poor results. If I pick it up and try again in a few hours, I may have a short time to work before the screen goes dark. The batteries are new. I think this might be a case of blown capacitors on board, but I could use insight. The motherboard costs more than the camera now.
Stephen Scanlan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 23
전체 시간: 1,975
