주요 콘텐츠로 건너뛰기
Nikon Coolpix P100 Display Screen Replacement
필요한 것
  1. Nikon Coolpix P100 Display Screen Replacement, Display Screen: 1 단계, 이미지 3개 중 1개 Nikon Coolpix P100 Display Screen Replacement, Display Screen: 1 단계, 이미지 3개 중 2개 Nikon Coolpix P100 Display Screen Replacement, Display Screen: 1 단계, 이미지 3개 중 3개
    • Flip the camera upside down so that the side with the serial number is face up.
    • Pull back the display panel. Orient the panel so that you are able to view the back of it.
  2. Nikon Coolpix P100 Display Screen Replacement: 2 단계, 이미지 2개 중 1개 Nikon Coolpix P100 Display Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two screws closest to the piece connecting the panel to the camera with a Phillips #1 screwdriver.
  3. Nikon Coolpix P100 Display Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the cover that was unscrewed in the last step.
  4. Nikon Coolpix P100 Display Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the remaining four screws on the outermost corners of the panel using a Phillips #1 screwdriver.
  5. Nikon Coolpix P100 Display Screen Replacement: 5 단계, 이미지 3개 중 1개 Nikon Coolpix P100 Display Screen Replacement: 5 단계, 이미지 3개 중 2개 Nikon Coolpix P100 Display Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to pry open the back panel of the display screen.
  6. Nikon Coolpix P100 Display Screen Replacement: 6 단계, 이미지 3개 중 1개 Nikon Coolpix P100 Display Screen Replacement: 6 단계, 이미지 3개 중 2개 Nikon Coolpix P100 Display Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully unhook the ribbon that attaches the panel to the camera.
    • Remove the top black panel cover.
  7. Nikon Coolpix P100 Display Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the two screws on the panel that are closest to the ribbon cable using a Phillips #1 screwdriver.
  8. Nikon Coolpix P100 Display Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the other two screws on the opposite side of the panel using a Phillips #1 screwdriver.
  9. Nikon Coolpix P100 Display Screen Replacement: 9 단계, 이미지 2개 중 1개 Nikon Coolpix P100 Display Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Separate the metal portion of the screen from the plastic portion.
  10. Nikon Coolpix P100 Display Screen Replacement: 10 단계, 이미지 2개 중 1개 Nikon Coolpix P100 Display Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Carefully remove the ribbon connector cable from the metal portion of the display.
    • Remove the display from the rest of the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Rikki Brown
회원 가입일: 01/09/15
279 평판
안내서 2개를 작성함
USF Tampa, Team 1-1, Tanski Winter 2015 USF Tampa, Team 1-1, Tanski Winter 2015 회원
USFT-TANSKI-W15S1G1
3 회원들
안내서 8개를 작성함
3가이드 댓글
This guide help me to change my screen on Nikon P100 with out to much trouble, however I found step 7 unnecessary.
David Fyock - 답글
Hello, I've a problem during the re-mount of the display. Someone can help me? Thanks in advance! Mark
cwmark56 - 답글
I can't reconnect the connector on the step 10. Can you help me?
cwmark56 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 29
전체 시간: 3,352
