주요 콘텐츠로 건너뛰기
Nikon Coolpix P100 Viewfinder Replacement
필요한 것
  1. Nikon Coolpix P100 Viewfinder Replacement, Nikon Coolpix P100  Motherboard Access: 1 단계, 이미지 1개 중 1개
    • Turn the front of the camera toward you.
  2. Nikon Coolpix P100 Viewfinder Replacement: 2 단계, 이미지 3개 중 1개 Nikon Coolpix P100 Viewfinder Replacement: 2 단계, 이미지 3개 중 2개 Nikon Coolpix P100 Viewfinder Replacement: 2 단계, 이미지 3개 중 3개
    • On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two marked screws.
  3. Nikon Coolpix P100 Viewfinder Replacement: 3 단계, 이미지 1개 중 1개
    • On the right side of the camera, remove the first visible screw above the HDMI and A/V OUT cover.
  4. Nikon Coolpix P100 Viewfinder Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the HDMI and A/V OUT cover to access the hidden screw between the two ports.
    • Remove the screw
  5. Nikon Coolpix P100 Viewfinder Replacement: 5 단계, 이미지 1개 중 1개
    • Flip the camera upside down and remove the seven marked screws.
  6. Nikon Coolpix P100 Viewfinder Replacement: 6 단계, 이미지 2개 중 1개 Nikon Coolpix P100 Viewfinder Replacement: 6 단계, 이미지 2개 중 2개
    • Turn the back of the camera toward you.
    • Lift the display panel and remove the two marked screws
  7. Nikon Coolpix P100 Viewfinder Replacement: 7 단계, 이미지 3개 중 1개 Nikon Coolpix P100 Viewfinder Replacement: 7 단계, 이미지 3개 중 2개 Nikon Coolpix P100 Viewfinder Replacement: 7 단계, 이미지 3개 중 3개
    • Use a plastic iFixit opening tool to gently loosen the top and sides of the camera.
  8. Nikon Coolpix P100 Viewfinder Replacement: 8 단계, 이미지 1개 중 1개
    • Before fully opening the camera, identify the two marked ribbon cables
    • Properly detach the ribbons before proceeding
  9. Nikon Coolpix P100 Viewfinder Replacement: 9 단계, 이미지 1개 중 1개
    • Carefully open the camera.
    • Now you have partial access to the camera's motherboard.
  10. Nikon Coolpix P100 Viewfinder Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the five indicated screws that are attached to the metal plate.
  11. Nikon Coolpix P100 Viewfinder Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the hidden top screw that is attached to the metal plate.
  12. Nikon Coolpix P100 Viewfinder Replacement: 12 단계, 이미지 1개 중 1개
    • Use a plastic iFixit opening tool to carefully loosen the metal plate.
    • Remove the metal plate to access the camera's motherboard.
  13. Nikon Coolpix P100 Viewfinder Replacement: 13 단계, 이미지 1개 중 1개
    • Now you have access to the camera's motherboard
  14. Nikon Coolpix P100 Viewfinder Replacement, Viewfinder: 14 단계, 이미지 1개 중 1개
    • Remove the screw that is located on the left of the view finder.
  15. Nikon Coolpix P100 Viewfinder Replacement: 15 단계, 이미지 1개 중 1개
    • Carefully detach the two ribbon cables and detach the viewfinder.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Nghiem Ngo
회원 가입일: 01/15/15
339 평판
안내서 2개를 작성함
USF Tampa, Team 1-1, Tanski Winter 2015 USF Tampa, Team 1-1, Tanski Winter 2015 회원
USFT-TANSKI-W15S1G1
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 13
전체 시간: 1,304
