이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Refer to the lens replacement guide for direction on disassembly.
필요한 것
Flip the camera upside down (have the side with the buttons facing away from you)
Look for the side with the triangle icon with three lines in it, this is the battery door. Add pressure and slide this door slightly until it clicks and pops open.
Once the door clicks, you can open it to reveal the slots holding the memory card and the battery.
Focusing on the larger slot, this holds the battery. Push the orange tab away from the slot, this will eject the old battery if one was previously inside.
Once this slot is open, you can place the new battery inside.
Locate the orange plug on the right side of the lens.
Carefully snap the plug out of place.
Remove the tab connecting the flash to the motherboard by gently pulling the connector sideways out of its port, away from flash unit.
Unsolder red and black wires.
Remove the flash unit.
