주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Nikon Coolpix P4 Motherboard Replacement
필요한 것
  1. Nikon Coolpix P4 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the camera upside down (have the side with the buttons facing away from you)
    • Look for the side with the triangle icon with three lines in it, this is the battery door. Add pressure and slide this door slightly until it clicks and pops open.
  2. Nikon Coolpix P4 Motherboard Replacement: 2 단계, 이미지 1/1
    • Once the door clicks, you can open it to reveal the slots holding the memory card and the battery.
    • Focusing on the larger slot, this holds the battery. Push the orange tab away from the slot, this will eject the old battery if one was previously inside.
    • Once this slot is open, you can place the new battery inside.
    • Make sure to close the orange tab to secure it in place!
  3. Nikon Coolpix P4 Motherboard Replacement, LCD Screen: 3 단계, 이미지 1/1
    • Remove the four 2.2 mm screws located on the bottom of the camera.
  4. Nikon Coolpix P4 Motherboard Replacement: 4 단계, 이미지 1/2 Nikon Coolpix P4 Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the two 2.9 mm screws from the side panel.
    • Remove the side panel.
  5. Nikon Coolpix P4 Motherboard Replacement: 5 단계, 이미지 1/3 Nikon Coolpix P4 Motherboard Replacement: 5 단계, 이미지 2/3 Nikon Coolpix P4 Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove the two 5 mm screws from the right side panel.
    • Remove the panel from the right side.
    • Remove the single 2.1 mm screw set underneath the panel.
  6. Nikon Coolpix P4 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the two 4.8 mm screws attaching the back panel to the body on the left side.
  7. Nikon Coolpix P4 Motherboard Replacement: 7 단계, 이미지 1/1
    • Gently pull off the back cover.
  8. Nikon Coolpix P4 Motherboard Replacement: 8 단계, 이미지 1/2 Nikon Coolpix P4 Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the three 4.8 mm screws from the A/V out tab on the left side.
    • Remove the tab.
  9. Nikon Coolpix P4 Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove the two 4.6 mm screws attaching the front panel to the body on the left side.
  10. Nikon Coolpix P4 Motherboard Replacement: 10 단계, 이미지 1/1
    • Flip up the front panel.
    • Potential for device damage. There should be wires still attaching the panel to the body. DO NOT TRY TO PULL OFF COMPLETELY.
  11. Nikon Coolpix P4 Motherboard Replacement: 11 단계, 이미지 1/1
    • Remove the 2.2 mm screw.
    • Remove the 2.9 mm screw.
    • Remove the 2.1 mm screw.
  12. Nikon Coolpix P4 Motherboard Replacement: 12 단계, 이미지 1/1
    • Carefully pull the orange LCD connector up and out of the port.
    • Be careful to pull vertically while pushing the black tab upwards
  13. Nikon Coolpix P4 Motherboard Replacement: 13 단계, 이미지 1/1
    • Remove the 3.1 mm screw below the LCD.
  14. Nikon Coolpix P4 Motherboard Replacement: 14 단계, 이미지 1/1
    • Carefully pull out the plug connecting the LCD to the motherboard.
  15. Nikon Coolpix P4 Motherboard Replacement: 15 단계, 이미지 1/1
    • Remove the LCD from the camera body.
  16. Nikon Coolpix P4 Motherboard Replacement, Motherboard: 16 단계, 이미지 1/1
    • Remove the screw to the right of the flash.
    • Remove the screw to the right of the microphone on the bottom. (0.124in)
  17. Nikon Coolpix P4 Motherboard Replacement: 17 단계, 이미지 1/1
    • Remove the two screws on the right side of the camera. (0.115 in screws)
  18. Nikon Coolpix P4 Motherboard Replacement: 18 단계, 이미지 1/1
    • Remove the four bottom screws. (0.116(fat head)-center screw, 0.112(skinny head)-other screws)
  19. Nikon Coolpix P4 Motherboard Replacement: 19 단계, 이미지 1/1
    • Remove the 7 screws from the back of the camera. (0.111 in screws)
  20. Nikon Coolpix P4 Motherboard Replacement: 20 단계, 이미지 1/1
    • Remove the plug that connects the lens to the left side of the motherboard by firmly grasping the base of the plug and pulling gently sideways away from the camera.
  21. Nikon Coolpix P4 Motherboard Replacement: 21 단계, 이미지 1/1
    • Remove the right panel.
  22. Nikon Coolpix P4 Motherboard Replacement: 22 단계, 이미지 1/1
    • Remove the screw from the top of the camera. (0.112 in screws)
  23. Nikon Coolpix P4 Motherboard Replacement: 23 단계, 이미지 1/1
    • Remove the three screws from the motherboard. (0.112 in screws)
    • Detach the orange tab with the foam on top. It will click out of place.
  24. Nikon Coolpix P4 Motherboard Replacement: 24 단계, 이미지 1/1
    • Remove the motherboard by pulling it up, out of the port.
  25. Nikon Coolpix P4 Motherboard Replacement: 25 단계, 이미지 1/1
    • Carefully remove the tab that connects the flash to the motherboard from the port by gently pulling connector to the right, out of its port.
    • Be careful when removing the connector.
  26. Nikon Coolpix P4 Motherboard Replacement: 26 단계, 이미지 1/1
    • Remove the motherboard from camera body.
    • Replace with a new motherboard and follow the steps in reverse order to reassemble.
결론
Luke Baumann
회원 가입일: 04/13/11
128 평판
안내서 5개 작성하였습니다
Cal Poly, Team 8-5, Regan Spring 2011 Cal Poly, Team 8-5, Regan Spring 2011 회원
CPSU-REGAN-S11S8G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 2,506
