주요 콘텐츠로 건너뛰기
Nikon Coolpix P510 Battery Removal Replacement
필요한 것
  1. Nikon Coolpix P510 Battery Removal Replacement, Battery Removal: 1 단계, 이미지 1/1
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 Battery Removal Replacement: 2 단계, 이미지 1/2 Nikon Coolpix P510 Battery Removal Replacement: 2 단계, 이미지 2/2
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
결론
Brian Hulsey
회원 가입일: 03/31/15
1,461 평판
안내서 6개 작성하였습니다
Colorado Springs, Team 2-2, Panko Spring 2015 Colorado Springs, Team 2-2, Panko Spring 2015 회원
UCCS-PANKO-S15S2G2
3 회원들
안내서 12개 작성하였습니다
댓글 3개
Even a 3 grader can figure this out. My problem is that I do this and the battery doesn't come up. It's stuck. What should I do???
victoria - 답글
Victoria, has had that problem too. In my case the battery was bloated. I had to wiggle it out with a butter knife until I could get a grip on it. I had to replace the battery.
david murray - 답글
Thank you so much for this information. I used a metal nail file and small pliers. It worked and the battery was swollen
klrider1961 -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 34
전체 시간: 4,116
