주요 콘텐츠로 건너뛰기
Nikon Coolpix P530 Battery Replacement
필요한 것
  1. Nikon Coolpix P530 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Identify the battery chamber found at the bottom of the device.
    • Ensure the camera is turned off before conducting any maintenance on the device.
  2. Nikon Coolpix P530 Battery Replacement: 2 단계, 이미지 1/3 Nikon Coolpix P530 Battery Replacement: 2 단계, 이미지 2/3 Nikon Coolpix P530 Battery Replacement: 2 단계, 이미지 3/3
    • Slide the switch to the left to open the battery chamber using your fingertip or plastic opening tools.
    • The spring loaded battery chamber door will swing open after the switch is moved.
  3. Nikon Coolpix P530 Battery Replacement: 3 단계, 이미지 1/3 Nikon Coolpix P530 Battery Replacement: 3 단계, 이미지 2/3 Nikon Coolpix P530 Battery Replacement: 3 단계, 이미지 3/3
    • Depress the yellow spring loaded tab holding the battery in place using your fingertip or plastic opening tools.
    • After the yellow tab is depressed, the battery should partially eject from the camera.
  4. Nikon Coolpix P530 Battery Replacement: 4 단계, 이미지 1/2 Nikon Coolpix P530 Battery Replacement: 4 단계, 이미지 2/2
    • Gently remove the battery from the chamber.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Alan Weihe
회원 가입일: 02/01/16
998 평판
안내서 7개 작성하였습니다
댓글 3개
Thanks. Just checking the camera issues.
Suzanne von Leuschner - 답글
I can’t get the battery out of my camera. I've had the camera for 5 years with no previous problems. Any suggestions?
Bonnie Laub - 답글
top of the battery gets very hot when inserted .Is this normal?
Lowell Schiller - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 28
전체 시간: 3,692
