주요 콘텐츠로 건너뛰기
Nikon Coolpix S210 Back Case Replacement
필요한 것
  1. Nikon Coolpix S210 Back Case Replacement, Battery: 1 단계, 이미지 1/1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Nikon Coolpix S210 Back Case Replacement: 2 단계, 이미지 1/2 Nikon Coolpix S210 Back Case Replacement: 2 단계, 이미지 2/2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
    Thank You!!! Amazing how easily I can complicate anything!! You are my hero. Retro picture taking ~ here I come!!
    Jennifer Curran - 답글
  3. Nikon Coolpix S210 Back Case Replacement, Back Case: 3 단계, 이미지 1/1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Nikon Coolpix S210 Back Case Replacement: 4 단계, 이미지 1/1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Nikon Coolpix S210 Back Case Replacement: 5 단계, 이미지 1/1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Nikon Coolpix S210 Back Case Replacement: 6 단계, 이미지 1/2 Nikon Coolpix S210 Back Case Replacement: 6 단계, 이미지 2/2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
결론
To reassemble your device, follow these instructions in reverse order, paying careful attention to the locations of the different sizes of screws.
다른 한 분이 해당 안내서를 완성하였습니다.
Paul Doyle
회원 가입일: 01/20/11
480 평판
안내서 3개 작성하였습니다
Cal Poly, Team 5-17, Amido Winter 2011 Cal Poly, Team 5-17, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G17
6 회원들
안내서 12개 작성하였습니다
댓글 한 개
What about the front case so I can replace the flash board on top?
danwat1234 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 2,250
