주요 콘텐츠로 건너뛰기
Nikon Coolpix S210 LCD screen Replacement
필요한 것
  1. Nikon Coolpix S210 LCD screen Replacement, Battery: 1 단계, 이미지 1/1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Nikon Coolpix S210 LCD screen Replacement: 2 단계, 이미지 1/2 Nikon Coolpix S210 LCD screen Replacement: 2 단계, 이미지 2/2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
    Thank You!!! Amazing how easily I can complicate anything!! You are my hero. Retro picture taking ~ here I come!!
    Jennifer Curran - 답글
  3. Nikon Coolpix S210 LCD screen Replacement, Back Case: 3 단계, 이미지 1/1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Nikon Coolpix S210 LCD screen Replacement: 4 단계, 이미지 1/1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Nikon Coolpix S210 LCD screen Replacement: 5 단계, 이미지 1/1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Nikon Coolpix S210 LCD screen Replacement: 6 단계, 이미지 1/2 Nikon Coolpix S210 LCD screen Replacement: 6 단계, 이미지 2/2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
  7. Nikon Coolpix S210 LCD screen Replacement, LCD screen: 7 단계, 이미지 1/3 Nikon Coolpix S210 LCD screen Replacement, LCD screen: 7 단계, 이미지 2/3 Nikon Coolpix S210 LCD screen Replacement, LCD screen: 7 단계, 이미지 3/3
    • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
    • The ribbons are connected to and held in place by small plastic latches.
    • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
    • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
  8. Nikon Coolpix S210 LCD screen Replacement: 8 단계, 이미지 1/1
    • Gently remove the LCD screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mallory Arend
회원 가입일: 01/17/11
444 평판
안내서 2개 작성하였습니다
Cal Poly, Team 5-17, Amido Winter 2011 Cal Poly, Team 5-17, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G17
6 회원들
안내서 12개 작성하였습니다
댓글 한 개
Funcionou conforme descrito! Funciona para a Nikon Coolpix S203
geral - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 3,963
