주요 콘텐츠로 건너뛰기
Nikon Coolpix S220 Accessing the Motherboard
필요한 것
  1. Nikon Coolpix S220 Accessing the Motherboard, Outer Cover: 1 단계, 이미지 1/1
    • Remove the two 2.8 mm screws on the left side of the camera.
  2. Nikon Coolpix S220 Accessing the Motherboard: 2 단계, 이미지 1/1
    • Remove the four 2.8 mm screws on the right side of the camera.
  3. Nikon Coolpix S220 Accessing the Motherboard: 3 단계, 이미지 1/1
    • Remove the three 4.1 mm screws on the bottom of the camera.
  4. Nikon Coolpix S220 Accessing the Motherboard: 4 단계, 이미지 1/1
    • Gently lift the rear cover from the camera.
  5. Nikon Coolpix S220 Accessing the Motherboard, LCD: 5 단계, 이미지 1/1
    • Gently lift the screen out of its place.
    • You will need to hold the screen slightly above the camera because it will still be attached to the camera by an orange ribbon cable.
  6. Nikon Coolpix S220 Accessing the Motherboard: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to lift the ZIF connector which is holding the ribbon cables that connect the LCD screen to the motherboard.
  7. Nikon Coolpix S220 Accessing the Motherboard: 7 단계, 이미지 1/1
    • Slowly pull the screen from the camera.
  8. Nikon Coolpix S220 Accessing the Motherboard, Motherboard: 8 단계, 이미지 1/1
    • Remove the four 3.8 mm screws located near the bottom right and top left of the LCD base plate.
  9. Nikon Coolpix S220 Accessing the Motherboard: 9 단계, 이미지 1/1
    • Lift up silver LCD base plate
  10. Nikon Coolpix S220 Accessing the Motherboard: 10 단계, 이미지 1/2 Nikon Coolpix S220 Accessing the Motherboard: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, lift up the retaining flap on the ZIF connector securing the button panel ribbon cable.
    • Slide the button panel ribbon cable out of its socket on the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Shauna
회원 가입일: 04/05/11
798 평판
안내서 5개 작성하였습니다
Cal Poly, Team 12-32, Maness Spring 2011 Cal Poly, Team 12-32, Maness Spring 2011 회원
CPSU-MANESS-S11S12G32
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
It would be nice to have a guide for replacing the flash capacitor.
danwat1234 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 15
전체 시간: 5,650
