소개
If the battery is dead or the memory card is full, it must be changed or charged. In order to accomplish either they must be removed. This guide will show the reader how to simply remove either one.
필요한 것
Slide the battery and memory card cover (located on the bottom of the camera) to release it.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Thank you! If you're like me, the way you push the memory card registers as "in," not "down," but I got it out!
bonitakale - 답글
