주요 콘텐츠로 건너뛰기
Nikon Coolpix S220 Battery and Memory Card Replacement
필요한 것
  1. Nikon Coolpix S220 Battery and Memory Card Replacement, Battery and Memory Card: 1 단계, 이미지 1/1
    • Slide the battery and memory card cover (located on the bottom of the camera) to release it.
  2. Nikon Coolpix S220 Battery and Memory Card Replacement: 2 단계, 이미지 1/1
    • To release battery you must slide the orange hatch, once doing so the battery will pop up.
    • Remove with tweezers or your fingers.
  3. Nikon Coolpix S220 Battery and Memory Card Replacement: 3 단계, 이미지 1/1
    • To release the memory card, simply push down on the memory card and it will pop up as the battery did.
    • You will be able to remove with your fingers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Shauna
회원 가입일: 04/05/11
798 평판
안내서 5개 작성하였습니다
Cal Poly, Team 12-32, Maness Spring 2011 Cal Poly, Team 12-32, Maness Spring 2011 회원
CPSU-MANESS-S11S12G32
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Thank you! If you're like me, the way you push the memory card registers as "in," not "down," but I got it out!
bonitakale - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 37
전체 시간: 19,130
