소개
If you happened to drop camera into dirt or sand, this guide will explain to you on how to clean it.
필요한 것
Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
Remove 2 screws from left side. (picture 1)
Remove 4 screws from bottom. (picture 2)
Remove 2 screws from right side. (picture 3)
Remove 2-2.10mm screws using a #000 Phillips screwdriver.
Gently pull the orange board to the right. (picture 2)
다른 2명이 해당 안내서를 완성하였습니다.
